Importing the Accelerator Project from Oracle Cloud Marketplace
All integration points are shipped as part of a single accelerator project (.car) file.
To import a pre-built integration from Oracle Cloud Marketplace:
2. Click Applications.
3. Search for “Utilities Analytics Insights Integration to Digital Asset Cloud & DERMS Int”. In Filter by Region/Country, select the North America checkbox.
4. Select the pre-built integration project to import.
5. Click GetApp.
6. Review and accept “Oracle Standard Terms and Restrictions”.
7. Click Next. My Oracle Support portal opens.
8. From the integration artifacts table, click the link to download the following Business Accelerator Project (.car) file: OUTL-BA-OUAI_DACS_DERMS-01.24.2000.car
9. Before importing the new Accelerator Project (.car) file into your Oracle Integration Cloud instance, do the following:
a. Back up the existing customized integrations and lookups.
b. Perform cleanup by deactivating and deleting the existing flows, connections, lookups, and libraries used in the integration and the .par package file.
Note: If your previous pre-built integration was package-based (.par file), you will see that:
• The package is visible on the Design-Packages page in your Oracle Integration Cloud instance.
• The individual integration flows will be visible on the Design-Integrations page. Each integration flow is designated with an Accelerator and BUILT BY ORACLE message displayed.
10. On the navigation pane, click Projects.
11. Click Add.
12. Select Import Project and drag-and-drop the .car file downloaded from Oracle Cloud Marketplace.
Note: Make sure to select the Anyone can edit, view, and monitor checkbox.
13. The new project will show up in the list with a status of Configured due to the connections not being completed yet.
14. Click Project Edit and follow the verification and configuration steps documented in the sections below.
15. If all configurations are complete, activate the integration by clicking Activate in the Design page, or activate the latest deployment plan in the Deploy page.
