Configuring Lookups
The following table lists the lookups that are part of this integration. This lookup is used for Char of Accounts Synchronization Integration Process.
DVM Name
Description
OUTL-BRT-WACS_ERPFIN_COAStatus
Map ERP Financial Chart of Account Code Combination Status to WACS Chart of Account Status
The following lookups are used by all the integration processes.
DVM Name
Description
OUTL-BRT-WACS_ERPFIN_ConfigProps
Maps PropertyName column to the respective Value Column. Do not change the values in PropertyName column.
OUTL-BRT-WACS_ERPFIN_Email_ID
Maps from and to recipient values to the mentioned email IDs.User can configure multiple emails by putting comma to separate the email IDs.
Editing Lookups
To edit a lookup:
1. Login to Oracle Integration for Cloud.
2. Navigate to Integrations > Designer > Lookups.
3. Select the look up to edit.
4. Make the necessary changes.
5. Click Save and Close.
