Solution Overview
The technical aspects involved in Oracle Utilities Work and Asset Cloud Service Integration to Oracle ERP Financial Cloud for General Ledger and Accounts Payable are:
• The integration layer is made up of integration processes deployed on Oracle Integration Cloud.
• The integration processes interact with other applications using the following adapters:
• Oracle ERP Cloud Adapter to import bulk data into Oracle ERP Financial Cloud by performing FBDI-compliant bulk operations like Journal Entries.
• REST Adapter to interact with Oracle Cloud Infrastructure Object Storage REST APIs
• FTP Adapter to retrieve files
• Oracle Utilities Adapter to interact with Oracle Utilities Work and Asset Cloud Service REST APIs.
• SOAP Adapter to interaction with Oracle UCM Generic Web Service to search, get and rename files in Oracle UCM.
• The integration pattern used for the solution is:
• One-way asynchronous for all flows
Refer to the Business Flows section for more information on each integration process.
