Activating Integration Flows
To activate the integration flows:
1. Navigate to the OU WACS ERPPIM project. In the Integrations section, select the integration to activate.
2. Drag the slider for that integration. When prompted to enable tracing, click Yes to view the instances.
3. Click Activate.
The integration takes time to get activated. The activated integration appears at the top of the integrations list.
