Importing the Oracle Accelerator Project from Oracle Cloud Marketplace
All integration points are shipped as part of single accelerator project (.car) file.
To import a pre-built integration from Oracle Cloud Marketplace:
1. Launch the Oracle Cloud Marketplace portal.
2. Click Applications.
3. Search for “Utilities Work and Asset Cloud Svc. Integration + Fusion Cloud Project Mgmt”.
4. Select the pre-built integration project.
5. Click GetApp.
6. Review and accept the “Oracle Standard Terms and Restrictions”.
7. Click Next. The My Oracle Support portal opens.
8. Download the integration package from My Oracle Support.
9. From the integration artifacts table, click the link to download the WACS-ERPPM Business Accelerator Project .car file.
• OUTL-BA-WACS_ERPSCM-01.24.2000.car
10. Perform the following steps before importing the new Accelerator project (.car) file into your Oracle Integration Cloud instance:
a. Take a backup of the existing customized integrations and lookups.
b. Perform the cleanup by deactivating and deleting the existing flows, connections, lookups, libraries used in the integration, and the .par package file.
Note: If your previous pre-built integration was packaged based (.par file), you will see:
• The package is visible on the Design-Packages page in your Oracle Integration Cloud instance.
• The individual integration flows are visible on the Design-Integrations page.
• Each integration flow is designated with an Accelerator and the “BUILT BY ORACLE” message is displayed.
11. In the Navigation pane, click Projects.
12. Click Add.
13. Select Import Project and drag-and-drop the .car file downloaded from Oracle Cloud Marketplace.
Note: Make sure to select the Anyone can edit, view, and monitor checkbox.
14. The new project will show up in the list, but with a “Configured” status due to the connections not being completed yet.
15. Click Project Edit and follow the verification and configuration steps documented in the following sections.
16. After all configurations are complete, click Activate on the Design page to activate the integration. Alternatively, you can activate the latest deployment plan in the on Deploy page.
