About Oracle Integration Cloud (OIC)
Oracle Integration Cloud is a unified platform to integrate the applications, automate processes, and create applications.
Using the Process Builder, business processes can be rapidly designed, automated, and managed in the cloud. Using integrations connect the applications into a continuous business flow. The integrations can be quickly developed and activated between both the applications that live in the cloud; and the applications still live on premises. The lookups help to match application specific codes between the two applications.
Integration Insights and Stream Analytics helps to simplify and extract business metrics and create custom dashboards.
