DVM Name | Description |
OUTL-BRT-WACS_ERPSCM_ConfigProps | Used to configure the integration properties. Maps the PropertyName column to the respective Value column. Note: Do not change the values under the PropertyName column. |
OUTL-BRT-WACS_ERPSCM_Country | Used to map ERPSCM Country to the WACS Country value. |
OUTL-BRT-WACS_ERPSCM_Email_ID | Used to configure email IDs to receive notifications. It maps the 'from' and 'to' recipient values to the mentioned email IDs. You can configure multiple emails by including a comma to separate the email IDs. |
OUTL-BRT-WACS_ERPSCM_State | Used to map ERPSCM State to the WACS State value. |
OUTL-BRT-WACS_ERPSCM_Item_UOM | Used to map the ERPSCM UOM value to the WACS UOM value. |
