Importing the Oracle Accelerator Project from Oracle Cloud Marketplace
All integration points are shipped as part of single accelerator project (.car) file.
To import a pre-built integration from Oracle Cloud Marketplace:
1. Launch the Oracle Cloud Marketplace portal.
2. Click Applications.
3. Search for “Oracle Utilities Work and Asset Cloud Service Integration to Supply Chain Management”. In the Region/Country filter, click the North America checkbox.
4. Select the pre-built integration project.
5. Click GetApp.
6. Review and accept “Oracle Standard Terms and Restrictions”.
7. Click Next. My Oracle Support portal opens.
8. From the integration artifacts table, click the link to download the WACS-ERPSCM OIC Accelerator Project .car file.
• OUTL-BA-WACS_ERPSCM-01.24.2000.car
9. Before importing the new Accelerator Project (.car) file into your Oracle Integration Cloud instance, do the following:
• Take a backup of the existing customized integrations and lookups.
• Perform cleanup by deactivating and deleting the existing flows, connections, lookups, libraries used in the integration, and the .par package file.
If your previous pre-built integration was packaged based (.par file), you will see:
• The package is visible on the Design-Packages page in your Oracle Integration Cloud instance.
• The individual integration flows are visible on the Design-Integrations page. Each integration flow is designated with an accelerator and the BUILT BY ORACLE message is displayed.
10. In the navigation pane, click Projects and then click Add.
11. Select Import Project and drag-and-drop the .car file downloaded from Oracle Cloud Marketplace.
Note: Make sure to select the Anyone can edit, view, and monitor checkbox.
12. The new project will show up in the list, but with the “Configured” status due to the connections not being completed yet.
13. Click Project Edit and follow the verification and configuration steps documented in the following sections.
14. If all configurations are complete, activate the integration by clicking Activate in the Design section, or activate the latest deployment plan in the Deploy section.
