Verifying the Project Import
To verify the OU WACS ERPSCM project import was successful:
1. Verify if the following integrations having version 1.24.2000 are imported successfully as seen in the Integrations section of the project:
OU ERPSCM WACS Active Storeroom Sync
OU ERPSCM WACS Inactive Storeroom Sync
OU ERPSCM WACS Storeroom SID Sync
OU ERPSCM WACS Stock Item Detail Bulk Load
OU ERPSCM WACS Stock Item Detail Incremental Sync
OU ERPSCM WACS Stock Item Detail Inv Adj Extract
OU ERPSCM WACS Stock Item Detail Inv Adjustment
OU ERPSCM WACS Zero Item Balances Scheduler
OU ERPSCM WACS Process Zero Item Balances
OU WACS ERPSCM Reservation Process
OU WACS ERPSCM Material Request Process
OU ERPSCM WACS Pick Wave Process
OU WACS ERPSCM Supply Request Monitor
OU WACS ERPSCM Common Error Handler
2. Verify if the following connections are in place.
OU BI ERP SCM for WACS-ERPSCM
OU SOAP WACS for WACS-ERPSCM
OU ERPSCM Cloud for WACS-ERPSCM
OU REST ERP for WACS-ERPSCM
OU SOAP UCM Generic Service for WACS-ERPSCM
OU REST WACS for WACS-ERPSCM
OU REST Trigger for WACS-ERPSCM
3. Make sure that the following lookups are imported successfully.
OUTL-BRT-WACS_ERPSCM_ConfigProps
OUTL-BRT-WACS_ERPSCM_Country
OUTL-BRT-WACS_ERPSCM_Email_ID
OUTL-BRT-WACS_ERPSCM_State
OUTL-BRT-WACS_ERPSCM_Item_UOM
OUTL-BRT-WACS_ERPSCM_Timezone
