Updating Quantities in ERP
To update quantity in Oracle Fusion Cloud ERP:
1. Login to Oracle Fusion Cloud ERP.
2. Navigate to Supply Chain Execution > Inventory Management.
3. On the Tasks menu, select the respective option. Example: Create Miscellaneous Transaction
a. Select the Orgnaization and Type.
b. For Current Item Cost, select “Yes”.
4. In the Transaction Lines section:
a. Enter the item for which the quantity needs to be adjusted.
b. Select the sub inventory.
c. Enter the quantity.
d. Select the account.
5. Click Save.
6. To verify if the quantity is added for the selected item:
a. On the Task menu, click Manage Item Quantities.
b. Search for the item.
c. Check the value for quantity.
