Property Name | Sample Value | Description | Used in Integration Process Name |
source.system | WACS | Defines the WAM or WACS product code | OU ArcGIS OFS Admin Files Create |
notification.email.error. flag | true | If the value is set to ‘true’, email notification will be sent out for errors. Valid values: true/false Default: true Also, setup the OUTL-BRT-ArcGIS_OFS_Email_ID 'to' property for the users or administrators who should receive the email. | OU ArcGIS OFS Admin Files Create |
ofs.activities.buckets | OHMeter | The property is used to configure the OFS buckets where the activities are assigned. | OU OFS ArcGIS Activities Sync flow |
wacs.projectedcoordinatesystem.wkid | 4326 | This property is used to configure the coordinates system [wkid] which will be used to retrieve the geometry coordinates in the specified system format. | OU OFS ArcGIS Activities Sync flow |
arcgis.asset.search | false | This property is used to enable or disable the asset search logic in the flow if the navigating to an asset based on search value feature is not used in the popup. Refer to the Oracle Field Service and ESRI ArcGIS Field Maps Configurations for ESRI ArcGIS Field Maps Integration to Oracle Field Service Mobile Setup Guide included in this release for more information on configuring links in the popup based on search value. The asset search property is used in the flow to get the value of search field element of the asset configured in the lookup. | OU OFS ArcGIS Activities Sync flow |
notification.email.invalidactivities.flag | False | If the value is set to 'true', email notification with invalid activities that have not been synchronized to ArcGIS will be sent out. As an example, the activities which has invalid longitude and latitude will not be synchronized and that activity information will be sent through the email if this flag is configured to true. | OU OFS ArcGIS Activities Sync flow |
activity.status.include | cancelled,started,completed,pending,suspended,enroute,notdone | The property is used to determine the status of the OFS activities that needs to be considered for add/update in Activites feature class. This list can be modified to remove the status so that activities belonging to that status will not be synchronized. | OU OFS ArcGIS Activities Sync flow |
notification.email.process.complete.flag | true | Configures the optional email notification. If the value is set to ‘true’, email notification will be sent to the configured users. Also, setup the OUTL-BRT-ArcGIS_OFS_Email_ID 'to.process.notification' property for the users or administrators who should receive the email. | OU ArcGIS OFS Admin Files Create |
asset.inventory.type | Asset | OU ArcGIS OFS Work Task Process | |
ofs.default.bucket | OHMeter | Configure the default bucket to assign the activities. | OU ArcGIS OFS Work Task Process |
notification.email.deleteactivities.flag | False | Sends a notification email when the delete process finishes. By default, flag is set to false. | OU OFS ArcGIS Activities Delete |
from | arcgis-ofs@email.com | Defines the WAM or WACS product code | OU ArcGIS OFS Admin Files Create |
to | errorDist@myCy.com | The email address(es) who should receive any error notification. Multiple emails can be configured by putting comma to separate the email IDs. These are likely the administrators or users who maintain the applications. | • OU OFS ArcGIS Activities Delete • OU OFS ArcGIS Activities Sync |
to.process.notification | busUserDist@myCy.com | The email address(es) who should receive notification when the processing has completed. Multiple emails can be configured by putting comma to separate the email IDs. These are likely the business or application users. | • OU ArcGIS OFS Admin Files Create • OU OFS ArcGIS Activities Delete |
