Publishing Feature Class on ArcGIS Online
To publish the Activities feature class either on ArcGIS Online or on ArcGIS Enterpriser Server:
1. Navigate to
Share >
Web Layer >
Publish Web Layer.
2. Enter the necessary information and configuration, analyze, and then publish the feature layer.
3. Make sure the assignment of unique IDs is enabled for the
<Activities> maps. Navigate to
Contents > <
Maps for Activities> >
Properties.
OAuth Security
The Activities feature layer on ArcGIS Online can be accessed using OAuth 2 Client Credentials in the “OU REST ArcGIS for ArcGIS-OFS” Oracle Integration Cloud connection.
To create an OAuth2 application:
1. Login to ArcGIS Online.
2. Create a
New Item of type
Developer Credentials.
3. Navigate to Settings to fetch the ClientId and Client secret of the application to use in the Oracle Integration Cloud connection.
