Publishing Feature Class on Standalone ArcGIS Enterprise Server
The Tasks feature class can be published as a REST service on the standalone ArcGIS Enterprise Server.
Note that the Task feature class does not need versioning enabled for its functionality.
To disable versioning and still have synchronization capability:
1. On the Tasks feature class properties, navigate to Manage > Archiving.
2. Make sure the Editor tracking checkbox is selected and the corresponding editor fields are mapped accurately.
3. Select the server connection that points to the Enterprise server to which the Task feature service needs to be deployed.
Refer to the Creating Server Connection section in Chapter 3: ArcGIS Pro Configurations for information about how to create server connection in ArcGIS Pro.
4. Click Publish and select the map to which the Tasks feature class has been added.
5. Enter the necessary information and publish the feature service in the Enterprise Server.
For additional information, refer to the following documentation:
