Required Software
The following software is required to configure and deploy the Tasks feature layer:
• ArcGIS Pro (3.2 or higher): A desktop client used to create database connection, server connection, load the domain and contingent values, and publish the Task layers to the server.
• ArcGIS Online or ArcGIS Enterprise Server: To publish the Tasks feature layer.
Note that if you are using Oracle database, the minimum version of Geodatabase supported is 10.9.1.
