Field Name | Description | Data Type |
OBJECTID | Object Id | Object ID |
SHAPE | Shape (Geometry) | Geometry |
ACTIVITY_NUM | WACS Activity number | Text |
ACTIVITY_TYPE | WACS Activity type | Text |
WORK_ORDER_DESC | Work order description | Text |
REQUIRED_BY_DATE | Required by date by which the activity must be completed | Date |
EMERGENCY_INDICATOR | If this activity is a emergency or not | Text |
CREW_ID | OFS Crew ID | Text |
CREW_NAME | OFS Crew name | Text |
GLOBAL_ID | Global Id | Global Id |
ACTIVITY_ID | OFS Activity ID | Text |
STATUS | OFS status of the activity | Text |
WORK_ORDER_ID | When integrated with WACS as part of WACS-OFS integration, this field represents the WAM work order ID. | Text |
ACTIVITY_DESC | Activity description | Text |
LOCATION_INFO | Activity location information | Text |
LINKED_ACTIVITIES | Linked activities. This field is not used currently. | Text |
ACTIVITY_DATE | Date the OFS activity was assigned. | Date |
CREATED_USER | ArcGIS editor field. It represents the ArcGIS user that created this feature record. It will be empty when created through OIC flow. | Text |
CREATED_DATE | ArcGIS editor field. It represents the date when the feature record was created in feature class. | Date |
LAST_EDITED_USER | ArcGIS editor field. It represents the ArcGIS user that updates this feature record. It will be empty when updated through the OIC flow. | Text |
LAST_EDITED_DATE | ArcGIS editor field. It represents the date when the feature record was updated in the feature class. | Date |
