Field Name | Description | Data Type |
OBJECTID | Object Id | Object ID |
GLOBALID | Global Id | Global Id |
ASSET_ID | When integrated with WACS as part of WACS-OFS integration, this field represents the WACS asset ID. | Text |
ACTIVITY_ID | OFS Activity ID | Text |
ASSET_DESC | When integrated with WACS as part of WACS-OFS integration, this field represents the WACS asset description. | Text |
GISID | When integrated with WACS as part of WACS-OFS integration, this field represents GISID of the asset which is ArcGIS Global ID of the Asset. | Text |
SEARCH_VALUE | Obtained value of the attribute configured on layer level search. | Text |
ASSET_INFO | When integrated with WACS as part of WACS-OFS integration, this field represents the asset information of the asset. | Text |
ACTIVITY_DATE | Date the OFS activity was assigned. | Text |
CREATED_USER | ArcGIS editor field. It represents the ArcGIS user that created this feature record. It will be empty when created through OIC flow. | Text |
CREATED_DATE | ArcGIS editor field. It represents the date when the feature record was created in feature class. | Date |
LAST_EDITED_USER | ArcGIS editor field. It represents the ArcGIS user that updates the feature record. It will be empty when updated through OIC flow. | Text |
LAST_EDITED_DATE | ArcGIS editor field. It represents the date when the feature record was updated in feature class. | Date |
