Using Activities and ActivityAssets
The Activities feature class and ActivityAssets table are used to store activities and related assets from Oracle Field Service. These activities are pulled from Oracle Field Service through the OU OFS ArcGIS Activities Sync OIC integration flow. The Oracle Field Service field worker can visualize these activities on maps:
• Activities and ActivityAssets workspace document is imported into the Enterprise geodatabase.
• A relationship class is created between the Activites feature class and ActivityAssets table.
• The Activities feature class is deployed as a feature layer. ActivityAssets table is deployed automatically as part of Activities feature layer.
• The Oracle Field Service activities in different status, created through the integration, are pulled through the scheduled integration flow run periodically.
• These activities and the related assets are created in Activities and ActivityAssets ArcGIS entities.
• The Activities and related assets can then be viewed on Fieldmaps through webmaps.
• A scheduled integration OU OFS ArcGIS Activities Delete is run at intervals to clean up Activities and ActivityAssets after a certain period.
