Configuring Time Zone
The TIMEZONE parameter in the CES_PARAMETERS database table specifies the name of the time zone used by the Oracle Utilities Network Management System backend services and database.
This parameter is used by the PK_CCB PL/SQL package to convert input data to the correct timezone for storing in the Oracle Utilities Network Management System database and to add timezone information to output data. A list of the time zone region names known to the database can be obtained from the V$TIMEZONE_NAME dynamic performance view. Time zone region name should be used instead of a simple offset to ensure that Daylight Savings Time is accounted for.
Example:
INSERT INTO CES_PARAMETERS (APP, ATTRIB, VALUE) VALUES ('NMS',
'TIMEZONE', 'America/Chicago');
