Configuring Lookups
The following table lists the lookups that are part of this integration.
Lookup Name
Integration Name
Purpose
OUTL-BRT-CCS_NMS_ACCOUNT_TYPE
Oracle Utilities CCS NMS Customer Sync
Transform CCS Service Type value to NMS Account Type value.
OUTL-BRT-CCS_NMS_ALARM_STATE
Oracle Utilities CCS NMS Job History
Transform Alarm State code between CCS and NMS.
OUTL-BRT-CCS_NMS_NEW_CALL_INDICATOR
Oracle Utilities CCS NMS Submit Calls
Transform CCS Outage Call Action code to NMS Update Existing Call Flag.
OUTL-BRT-CCS_NMS_CALL_CANCEL_INDICATOR
Transform CCS Status to NMS Call Cancel Flag value.
OUTL-BRT-CCS_NMS_ CALL_BACK_INIDICATOR
Transform callback indicator between CCS and NMS.
OUTL-BRT-CCS_NMS_CALL_STATUS
Oracle Utilities CCS NMS Call History
Transform Call Status between CCS and NMS.
OUTL-BRT-CCS_NMS_CAUSE
Transform Cause between CCS and NMS.
OUTL-BRT-CCS_NMS_ConfigProps
• Oracle Utilities CCS NMS Job History
• Oracle Utilities CCS NMS Planned Outages
• Oracle Utilities CCS NMS Submit Calls
• Oracle Utilities CCS NMS Call History
• Oracle Utilities CCS NMS Customer Sync
Configuration Properties for CCS-NMS Cloud Integration.
OUTL-BRT-CCS_NMS_EMAIL_ID
Oracle Utilities CCS NMS Global Error Handler
Define From and To emails for the Global Error Handler Notifications.
OUTL-BRT-CCS_NMS_ETR_SOURCE
Transform ETR Source code between CCS and NMS.
OUTL-BRT-CCS_NMS_INSTANCE
Define the CCS Division and its equal NMS instance mapping.
OUTL-BRT-CCS_NMS_JOB_HISTORY_STATUS
Transform Job History Status between CCS and NMS.
OUTL-BRT-CCS_NMS_SUPPORT_INDICATOR
Transform Life Support Indicator from CCS value to NMS value.
OUTL-BRT-CCS_NMS_MANUFACTURER
Transform Manufacturer from CCS to NMS.
OUTL-BRT-CCS_NMS_METER_TYPE
Transform Meter Type code from CCS to NMS.
OUTL-BRT-CCS_NMS_USAGESUB_
STATUS
Transform CCS usage subscription status value to NMS status value.
Editing Lookups
To edit a lookup:
1. Login to Oracle Integration for Cloud.
2. Navigate to Projects > Look for the project “OU CCS NMS” > Lookups dashlet.
3. Select the lookup to edit.
4. Make the necessary changes.
5. Click Save and Close.
