Importing the Oracle Integration Cloud Project Based Accelerator Package from Oracle Cloud Marketplace
All integration artifacts are shipped into single project (.car) file.
To import a pre-built integration from Oracle Cloud Marketplace:
1. Launch the Oracle Cloud Marketplace portal.
2. Click Applications.
3. Search for “Utilities Customer Cloud Service & Network Management System”.
4. Browse through the list of applications and select the pre-built integration project to import.
5. Click GetApp.
6. Review and accept “Oracle Standard Terms and Restrictions”.
7. Click Next. MyOracle Support portal opens.
8. From the integration artifacts table, download the Integration OIC accelerator project (.car) file.
9. Perform the following steps before importing the new project based accelerator project (.car) file into your Oracle Integration Cloud instance.
a. Take the backup of the existing customized integrations and lookups.
b. Perform cleanup by deactivating and deleting the existing flows, connections, lookups, libraries used in the integration, and the .par package file.
Note: If your previous pre-built integration was packaged based (.par file), you will see that:
• The package is visible on the Design-Packages page in the Oracle Integration Cloud instance.
• The individual integration flows are visible on the Design-Integrations Each integration flow are designated with an accelerator, and “BUILT BY ORACLE” message is displayed.
10. Navigate to Integrations > Projects.
11. Click Add.
12. Select Import Project and drag-and-drop the .car file downloaded from Oracle Cloud Marketplace.
Note: Make sure to select the Anyone can edit, view, and monitor checkbox.
The new project will show up in the list, but with the “Configured” status due to the connections not being completed yet.
13. Click Project Edit and follow the verification and configuration steps documented in the following sections.
14. If all configurations are complete, activate the integration by:
• Clicking Activate in the Design section.
• Or, activate the latest deployment plan in the Deploy section.
15. Verify if the project is imported is successfully.
