Supported Source Applications
The following table lists the supported application versions in this integration:
Application
Version
Oracle Utilities Customer Cloud Service
23A and higher
Oracle Utilities Customer to Meter
2.9.0.1.1
Oracle Utilities Network Management System
2.6.0.2 and higher
Oracle Integration Cloud
24.10.4.0.0 and higher
Refer to the
Certification Matrix for Oracle Utilities Products (Doc ID 1454143.1)
on
My Oracle Support
to determine if support for newer versions of the listed products is included.
This site works best with JavaScript enabled
