Importing the Oracle Accelerator Project from Oracle Cloud Marketplace
All integration points are shipped as part of a single accelerator project (.car) file.
To import a pre-built integration from Oracle Cloud Marketplace:
1. Launch the Oracle Cloud Marketplace portal.
2. Click Applications.
3. Search for “Utilities Network Management & Field Service Integration”.
a. Go to the marketplace link.
b. Search for the description of the integration product.
c. Use the integration product description to find “Utilities Network Management & Field Service Integration”.
4. Download the NMS-OFS Business Accelerator Project file.
a. Select the pre-built integration project.
b. Click GetApp.
c. Review and accept “Oracle Standard Terms and Restrictions”.
d. Click Next.
My Oracle Support portal opens.
e. From the integration artifacts table, click the NMS-OFS Business Accelerator Project (OUTL-BA-NMS_OFS-01.24.3000.car) download link.
5. Back up and clean up existing integration and package files.
a. Back up existing customized integrations and lookups.
b. Deactivate and delete existing flows, connections, lookups, and libraries used in the integration and the .par package file.
Note: If your previous pre-built integration was Package based (.par file) which is identified by:
• It is visible on the Design-Packages page in your Oracle Integration Cloud instance.
• The individual integrations are visible on the Design-Integrations page. Each integration flow is designated with an Accelerator and BUILT BY ORACLE message displayed.
6. Import the NMS-OFS Business Accelerator Project (.car) file to your Oracle Integration Cloud instance.
a. In the Navigation pane, click Projects.
b. Click Add.
c. Select Import Project and drag-and-drop the .car file downloaded from Oracle Cloud Marketplace.
Note: Select the Anyone can edit, view, and monitor checkbox.
The new project will show up in the list but with a status of “Configured” due to the connections not being completed yet.
7. Verify, configure, and activate the integration.
a. Click the Project Edit option and follow the verification and configuration steps documented in the sections below.
b. If all configuration is complete, activate the integration by one of these methods.
• Click Activate in Design.
• Activate the latest deployment plan Deploy.
