Configuring Connections in Oracle Integration Cloud
After the project is imported and verified, configure the respective connections.
This section describes the procedure to set up the following connections:
• Oracle Utilities REST NMS1 for NMS-OFSC
• Oracle Utilities REST OFSC for NMS-OFSC
• Oracle Utilities REST API OFSC for NMS-OFSC
• Oracle Utilities REST OIC for NMS-OFSC
• Oracle Utilities REST for NMS-OFSC
Configuring Oracle Utilities REST NMS1 for NMS-OFSC
This connection is used to trigger from or invoke to the Oracle Utilities Network Management System using the Oracle Utilities Adapter.
To configure the connection:
1. Add the Oracle Utilities Network Management System catalog URL.
• Format: https://{NMS-Host}:{NMS-Port}/nms-ofs/rest/v1/catalog
2. On the Security section, select the applicable security policy to access the application.
For more information about supported security policies, refer to the Oracle Utilities Adapter documentation.
3. When the connection is to the Oracle Utilities Network Management System on-premise application:
a. Configure the appropriate Agent Group.
b. Select the agent group from the list created in the Creating an Agent Group procedure.
4. On the Connection page, click Test.
5. After the connection is tested successfully, click Save.
This connection is used by the following integrations:
• Oracle Utilities NMS OFSC Ping
• Oracle Utilities NMS OFSC Order
• Oracle Utilities NMS OFSC Order Async
• Oracle Utilities NMS OFSC OrderComplete
• Oracle Utilities NMS OFSC OrderComplete Async
• Oracle Utilities NMS OFSC Crew Request
• Oracle Utilities NMS OFSC Crew Request Async
• Oracle Utilities NMS OFSC Attachment
• Oracle Utilities NMS OFSC Admin Sync
• Oracle Utilities OFSC NMS Activity Create
• Oracle Utilities OFSC NMS Activity Update
• Oracle Utilities OFSC NMS Attachments
• Oracle Utilities OFSC NMS Event Details Update
• Oracle Utilities OFSC NMS Failed Equipment Update
• Oracle Utilities OFSC NMS Resource Create Update
• Oracle Utilities OFSC NMS Resource Route
• Oracle Utilities OFSC NMS Resources Sync
Configuring Oracle Utilities REST OFSC for NMS-OFSC
This connection is used to communicate with Oracle Field Service using the Oracle Field Service adapter via a trigger or invoke.
Configure the Oracle Field Service connection with the required details:
1. Enter the API URL in the Oracle Field Service with this format:
• https://<ofs instance id>.fs.ocs.oraclecloud.com/rest
2. Re-enter the Instance ID.
3. Select the appropriate Security Policy.
• For more information about supported security policies, refer to the REST Adapter documentation.
4. Enter the appropriate credentials based on the selected security policy and click Test.
Note: Make sure to configure the client and client secret part of the username and password. Retrieve them by logging into Oracle Field Service.
This connection is used by these integrations:
Configuring Oracle Utilities REST API OFSC for NMS-OFSC
This connection is used to sync invoke or get triggered from OFSC API using the REST adapter.
Configure the Oracle Utilities REST OFSC for NMS-OFSC connection with required details:
1. On the Connection page, select REST API Base URL from the Connection Type drop-down.
2. Enter the API URL in the Oracle Field Service with this format:
3. Select the TLS Version as TLSV1.2.
4. Select the appropriate Security Policy.
5. Enter the appropriate credentials based on the selected security policy and click Test.
• Note: Make sure to configure the client and client secret part of the username and password. Retrieve them by logging into Oracle Field Service.
6. After the connection is tested successfully, click Save.
Note: This connection is used by the following processes:
• Oracle Utilities NMS OFSC Chat Notification
• Oracle Utilities OIC OFSC Find Resource Bucket
Configuring Oracle Utilities REST OIC for NMS-OFSC
This connection is used to communicate with Oracle Integration itself using REST adapter.
1. Select REST API Base URL from the Connection Type drop-down.
2. Enter "https://{OIC-Instance}:{OIC-Host} in the Connection URL field.
3. From the Security Policy drop-down, select OAuth Client Credentials.
4. Configure the Access Token URI, Client ID, and Client Secret fields respectively from the OIC instance.
5. Open the Optional Security fields and configure:
• Scope
• Client Authentication as Send client credentials as basic auth header
6. On the Connection page, click Test.
7. After the connection is tested successfully, click Save.
Note: This connection is used by the following integrations:
Configuring Oracle Utilities REST for NMS-OFSC
This connection is used to design local integrations entry point and invoke these within Oracle Integration Cloud using the REST adapter.
1. Select OAuth 2.0 or Basic Authentication
2. Verify that Role is set as Trigger.
3. Click Save.
• Oracle Utilities NMS OFSC Order Async Process
• Oracle Utilities NMS OFSC OrderComplete Async Processor
• Oracle Utilities NMS OFSC Common Error Handler
