Supported Applications
The following table lists the supported application versions in this integration:
Version
Oracle Utilities Network Management System
V2.6.0.1.0 or higher
Oracle Integration Cloud
V24.10 and higher
Oracle Field Service
24C or higher
Refer to the Certification Matrix for Oracle Utilities Products (Doc ID 1454143.1) on My Oracle Support to determine if support for newer versions of the listed products is included.
