Configuring Lookups
The following table lists the lookups that are part of this integration.
DVM Name
Description
OUTL-BRT- WACS_FPRC_ConfigProps
Maps the PropertyName column to the respective Value column. Do not change the value in the PropertyName column.
OUTL-BRT-WACS_FPRC_Country
Maps Country values between Oracle Fusion Procurement Cloud and Oracle Utilities Work and Asset Cloud Service.
Get WACS values from Admin > [C or General] > Country > Search.
Get FPRC values from Manage > Geography Lookup.
OUTL-BRT- WACS_FPRC_CurrencyCode
Maps Currency code between Oracle Fusion Procurement Cloud and Oracle Utilities Work and Asset Cloud Service.
Get WACS values from Admin > [C or General] > Currency.
Get FPRC values from Define Currency and Currency Rate > Manage Currency.
OUTL-BRT- WACS_FPRC_DeliverToLocation
Maps between Oracle Fusion Procurement Cloud Deliver To Location Code and Oracle Utilities Work and Asset Cloud Service Ship To Location Code. In Oracle Utilities Work and Asset Cloud Service, Ship To Location is a storeroom.
Get WACS values from Admin > [S or Inventory] > Storeroom > Search.
Get FPRC values from Procurement > Manage Location.
OUTL-BRT-WACS_FPRC_Email_ID
Maps from and to recipient values to the mentioned email IDs. Configure multiple emails using a comma to separate the email IDs.
OUTL-BRT-WACS_FPRC_FOB
Maps FOB values between Oracle Fusion Procurement Cloud and Oracle Utilities Work and Asset Cloud Service.
Get WACS values from Admin > [F or Purchasing] > Free On Board > Search.
Get FPRC values from Manage > Freight Terms Lookup.
OUTL-BRT-WACS_FPRC_InvoiceLineType
Maps Invoice Line Type Code between Oracle Fusion Procurement Cloud and Oracle Utilities Work and Asset Cloud.
Get WACS values from Admin > L or Database > Lookup > Search > Search for INVOICE_ITEM_TYPE_FLG
Get FPRC values from Manage > Setup and Maintenance > Manage Invoice Option
OUTL-BRT- WACS_FPRC_ItemTypeCode
Maps between Oracle Fusion Procurement Cloud Item Type Code and Oracle Utilities Work and Asset Cloud Service Item Type Code.
Get WACS values from Admin > L or Database > Lookup > Search > Search for ITEM_TYPE_FLG
Get FPRC values from Define > Purchase Order Line Type
OUTL-BRT- WACS_FPRC_PaymentTerm
Maps Payment Term values between Oracle Fusion Procurement Cloud to Oracle Utilities Work and Asset Cloud Service.
Get WACS values from Admin > P or Purchasing > Payment Terms > Search
Get FPRC values from Financials > Manage Payment Terms
OUTL-BRT-WACS_FPRC_PaymentType
Maps between Oracle Fusion Procurement Cloud Payment Type and Oracle Utilities Work and Asset Cloud Service Check Type Code.
Get WACS values from Admin > L or Database > Lookup > Search > Search for CHECK_TYPE_FLG (Customizable)
Get FPRC values from Financial > Define Payment method
OUTL-BRT- WACS_FPRC_POLineStatus
Maps Oracle Fusion Procurement Cloud Document Status Code to Oracle Utilities Work and Asset Cloud Service PO Status Code.
Sample values:
FPRC -OPEN, CANCELED, FINALLY CLOSED
WACS - ISSUED, CANCELED, CLOSED
OUTL-BRT- WACS_FPRC_POStatus
Maps the Oracle Fusion Procurement Cloud Document Status Code to Oracle Utilities Work and Asset Cloud Service PO Status Code.
Sample values:
• FPRC - OPEN, CANCELED, FINALLY CLOSED
• WACS - ISSUED, CLOSED
OUTL-BRT-WACS_FPRC_State
Maps state values between Oracle Fusion Procurement Cloud and Oracle Utilities Work and Asset Cloud Service.
Get WACS values from Admin > [C or General] > Country > Search for a Country > State tab.
OUTL-BRT-WACS_FPRC_UOM
Maps between Oracle Utilities Work and Asset Cloud Service UOM Code and Oracle Fusion Procurement Cloud UOM Name.
Get WACS values from Admin > U or Inventory > Unit Of Measure - Resource > Search.
Get FPRC values from Manage > Unit of Measure.
OUTL-BRT-WACS_FPRC_BCStatus
Maps between Oracle Fusion Procurement Cloud Blanket Contract status to Oracle Utilities Work and Asset Cloud Service Blanket Contract status.
Sample values:
• FPRC_Status: OPEN, CANCELED,WITHDRAWN, ON HOLD, FINALLY CLOSED
• WACS Status: ACTIVE,CLOSED,SUSPENDED
OUTL-BRT-WACS_FPRC_BC_Category
Maps between Oracle Fusion Procurement Cloud Blanket Contract Category to Oracle Utilities Work and Asset Cloud Service Blanket Contract Category.
Note: This integration supports Blanket Purchase Agreement and Contract Purchase Agreement. Blanket Purchase Agreement must be configured as “BPA” in WACS, BLANKET_CATEGORY_FLG custom lookup Contract Purchase Agreement must be configured as “CPA” in WACS, BLANKET_CATEGORY_FLG custom lookup.
Get WACS values from Admin > [L or Database] > Lookup > Search for the BLANKET_CATEGORY_FLG lookup.
This lookup is a custom lookup with values defined by implementation. There is no system processing, but the values and descriptions will be used to indicate if the Blanket Contract is a Blanket Purchase Agreement (or Blanket Contract) or Contract Purchase Agreement.
Editing Lookups
To edit a lookup:
1. Login to Oracle Integration for Cloud.
2. Navigate to Projects.
3. Select the project and navigate to the Lookups section of the project.
4. Select the lookup to edit.
5. Make the necessary changes.
6. Click Save and Close.
