Software Requirements
The following table lists the supported applications and the respective versions:
Source Application
Version
Oracle Utilities Work and Asset Cloud Service
24C or higher
Oracle Integration Cloud
V24.10 and higher
Oracle Fusion Procurement Cloud
24C or higher
Oracle Financial Cloud
24C or higher
Refer to the Certification Matrix for Oracle Utilities Products (Doc ID 1454143.1) on My Oracle Support to determine if support for newer versions of the listed products is included.
