Importing the Oracle Integration Cloud Project from Oracle Cloud Marketplace
All integration points are shipped as part of single project (.car) file.
To import a pre-built integration from Oracle Cloud Marketplace:
2. Click Applications.
3. Search for “Oracle Utilities Work and Asset Cloud Service”.
4. Browse through the list of applications and select the pre-built integration OU WACS ERPFA project to import.
5. Click GetApp.
6. Review and accept “Oracle Standard Terms and Restrictions”.
7. Click Next. My Oracle Support portal opens.
8. Download the integration package from My Oracle Support.
9. When prompted, select the server where the pre-built integration file should be uploaded.
The pre-built integration is imported as a project file OU WACS ERPFA that is visible on the Project page in Oracle Integration Cloud.
10. On the Integrations page, the individual integrations of the imported package file that are designated with a BUILT BY ORACLE message are displayed.
Important! This note is applicable only for existing customers. Make sure to take a backup of the existing package and lookups, and perform the cleanup before proceeding with the new package import. The cleanup includes deactivating the existing flows in this package and deleting the package, connections, lookups and libraries used in the integration.
To import a package in Oracle Integration Cloud:
1. Login to Oracle Integration Cloud.
2. Navigate to Integrations > Designer > Project.
3. Click Import.
4. Select the .car file downloaded from Oracle Cloud Marketplace.
5. Verify if the project is imported successfully.
