Importing the Oracle Integration Cloud Project from Oracle Cloud Marketplace
All integration flows are shipped as part of single accelerator project (.car) file.
To import a pre-built integration from Oracle Cloud Marketplace:
1. Launch the Oracle Cloud Marketplace portal.
2. Click Applications.
3. Search for “Oracle Utilities Work and Asset Cloud Service”.
4. Browse through the list of applications and select the pre-built integration project to import.
5. Click GetApp.
6. Review and accept “Oracle Standard Terms and Restrictions”.
7. Click Next. My Oracle Support portal opens.
8. From the integration artifacts table, click the link to download WACS-OFSC Business Accelerator Project (OUTL-BA-WACS_OFSC-01.24.3000.car).
9. Perform these steps before importing the new Accelerator Project (.car) file into your Oracle Integration Cloud instance.
a. Take a backup of the existing customized integrations and lookups.
b. Perform cleanup by deactivating and deleting the existing flows, connections, lookups, and libraries used in the integration and the .car project file.
Note: If your previous pre-built integration was project based (.car file), you will see:
• The project is visible on the Projects page in your Oracle Integration Cloud instance.
• The individual integration flows are visible on the Design-Integrations. Each integration flow is designated with an Accelerator and BUILT BY ORACLE message.
10. On the Integrations page, the individual integrations of the imported project file that are designated with a BUILT BY ORACLE message are displayed.
To import a project in Oracle Integration Cloud:
1. Login to Oracle Integration Cloud.
2. Navigate to Projects.
3. Click Add.
4. Select Import Project and drag-and-drop the .car file downloaded from Oracle Cloud Marketplace.
Note: Make sure to select the Anyone can edit, view, and monitor checkbox.
5. The new project will show up in the list but with a “Configured” status due to the connections not being completed yet.
6. Click Project Edit and follow the verification and configuration steps documented in the sections below.
7. If all configurations are complete, activate the integration by:
• Clicking Activate in the Design.
• Or activating the latest deployment plan in the Deploy.
8. Verify if the OU WACS OFSC project is imported successfully.
