Timesheet/ Other Direct Charges Flag
This flag indicates whether a mobile worker is allowed to add a timesheet or other direct charges for an activity that has been completed.
In the Oracle Utilities Work and Asset Management master configuration, the following properties accept the Yes or No values.
• Allow Timesheet against completed activity.
• Allow ODC against completed activity.Work Management Master Configuration page Main tab showing the Master Configuration Details.
To set the value of these properties in Oracle Field Service:
1. Navigate to Configuration > Resources, Activities, Inventories > Properties. Search for Resource Usage Flag.Properties page showing the Resource Usage Flag.
2. Click Modify. Go to the Enumeration values section. TS and ODC indicate Timesheet and Other Direct Charges respectively. Default value for both flags is “NO”.Modify Property window showing the Combobox and the Active checkboxes selected. The Update button is located on the bottom right corner.
3. To change the value of flags, select or unselect the Active checkbox to make the corresponding enum values of YES/NO active or inactive respectively.
4. Click Change > Update to reflect the changes. Else, click Cancel.
