Creating a Backup
Take a backup of the following:
• Oracle Integration Cloud Pre-built Integration Project: If the accelerator is project-based, export the Oracle Integration Cloud project. Click Export on the navigation bar for the respective project.
To export the project:
a. Login to Oracle Integration Cloud.
b. Navigate to Projects.
c. Select the project to be exported.
d. Click Export on the navigation bar list.
• Oracle Integration Cloud Pre-built Integration Package: If the accelerator is package based, export the Oracle Integration Cloud package and integration flows from Oracle Integration Cloud and store them in the local folder.
Note: If the base project is cloned and customizations are included in the cloned flows or if an older version of the project existed before consuming Oracle Integration Cloud accelerator project (outl.ba.wacs_ofsc.01_24_3000.car), take a backup of the Oracle Integration Cloud project.
To export the package and integration flows:
b. Navigate to Packages from integrations.
c. Select the required package to be exported.
d. Browse to the path where the package should be exported to and click Export.
• Oracle Field Service Properties: Export the Oracle Field Service properties that start with “wam_” and store/save them in the local folder.
• Oracle Field Service User Type: Export the user type file from the Oracle Field Service environment.
• Oracle Field Service Plugin: Export the Oracle Field Service plugin from the Oracle Field Service environment.
For detailed steps to create a backup, refer to the Oracle Utilities Work and Asset Cloud Service Integration to Oracle Field Service Configuration Guide included in this release. The documentation is available on Oracle Help Center at: https://docs.oracle.com/en/industries/energy-water/integrations-index.html
