Verifying the Project Import
To verify the OU WACS ERPSCM project import was successful:
1. Verify if the following integrations having version 1.24.3000 are imported successfully as seen in the Integrations section of the project:
• OU ERPSCM WACS Active Storeroom Sync
• OU ERPSCM WACS Inactive Storeroom Sync
• OU ERPSCM WACS Storeroom SID Sync
• OU ERPSCM WACS Stock Item Detail Bulk Load
• OU ERPSCM WACS Stock Item Detail Incremental Sync
• OU ERPSCM WACS Stock Item Detail Inv Adj Extract
• OU ERPSCM WACS Stock Item Detail Inv Adjustment
• OU ERPSCM WACS Zero Item Balances Scheduler
• OU ERPSCM WACS Process Zero Item Balances
• OU WACS ERPSCM Reservation Process
• OU WACS ERPSCM Material Request Process
• OU ERPSCM WACS Pick Wave Process
• OU WACS ERPSCM Supply Request Monitor
• OU WACS ERPSCM Common Error Handler
2. Verify if the following connections are in place.
• OU BI ERP SCM for WACS-ERPSCM
• OU SOAP WACS for WACS-ERPSCM
• OU ERPSCM Cloud for WACS-ERPSCM
• OU REST ERP for WACS-ERPSCM
• OU SOAP UCM Generic Service for WACS-ERPSCM
• OU REST WACS for WACS-ERPSCM
• OU REST Trigger for WACS-ERPSCM
3. Make sure that the following lookups are imported successfully.
• OUTL-BRT-WACS_ERPSCM_ConfigProps
• OUTL-BRT-WACS_ERPSCM_Country
• OUTL-BRT-WACS_ERPSCM_Email_ID
• OUTL-BRT-WACS_ERPSCM_State
• OUTL-BRT-WACS_ERPSCM_Item_UOM
• OUTL-BRT-WACS_ERPSCM_Timezone
