Supported Source Applications
The following table lists the supported applications and the respective versions:
Source Application
Version
Oracle Utilities Work and Asset Cloud Service
24C or later
Oracle Integration Cloud
V24.10 and higher
Oracle Supply Chain Management
24C or later
This site works best with JavaScript enabled
