Known Issues
Following is a list of known issues at the time of this integration release:
• The Stock Item Details integration does not consider tracked assets in the 24A release.
• To create a stock item as soon as the synchronization request is created, remove the “Pending” status monitor for the Stock Item Ongoing Sync Request business object in Oracle Utilities Work and Asset Cloud Service. This allows you to create the stock item details (SID) after the stock item is created.
• If the Storeroom SID synchronization flow fails with the following error, follow the instructions in Doc ID 2786681.1 for resolution:
“You must enter at least 3 characters in one of these fields: ItemNumber,ItemDescription,Keyword. (EGP-2776154)”.
• In Inventory Adjustment BI report, if the parameters are not shown on the Data tab in the Data Model page, add a default value and save it. Make sure the parameter is visible. Remove the default value and save it again.
