Special Character Handling
A character combination of ‘<>’ in the files generated from Oracle Utilities Work and Asset Cloud Service is not processed by the applyEdit ArcGIS Rest API. Hence, this character combination is not supported by the OU WACS ArcGIS Assets Update flow as well.
