Integration Overview
Geographic Information Systems (GIS) play a key role in day-to-day operations of utility companies. GIS represents a foundational layer of technology for effective asset management and regulatory compliance. GIS can be leveraged for various purposes, including asset inventory and infrastructure insights, field operations management, digitizing the data collection process, and more.
The ESRI ArcGIS to Oracle Utilities Work and Asset Cloud Service integration, built in Oracle Integration Cloud, enables asset and location synchronization between ESRI ArcGIS and Oracle Utilities Work and Asset Cloud Service. With support for ESRI version 11 and the Utility Network Model, the solution provides support for the latest ESRI software versions and data models, enhanced data consistency, and improved geospatial and asset management capabilities.
This solution provides:
• Empowered Decision-Making: Provides precise geospatial insights for faster, data-driven utility management.
• Extended Use Cases: Manages complex asset-location relationships, multi-utility datasets, and improved monitoring via Oracle Integration Cloud.
• Full Compatibility: Supports ESRI ArcGIS version and the Utility Network Model for seamless integration.
• Multiple ESRI Enterprise Portal Support and Scalability: Supports multiple ESRI ArcGIS environments, enabling broader adoption across different utility landscapes.
• Optimized Performance and Ease of Use: Utilizes modern ESRI ArcGIS and Oracle Integration Cloud technology stacks to improve processing speeds, reduce errors, and simplify user interaction.
In this integration release, the following features are included:
• Ability to perform a full/initial synchronization of asset and asset locations from ESRI ArcGIS to Oracle Utilities Work and Asset Cloud Service.
• Incremental synchronization from ESRI ArcGIS to Oracle Utilities Work and Asset Cloud Service for assets that have been added, updated, and deleted.
• Synchronizing extendable lookups from Oracle Utilities Work and Asset Cloud Service to Oracle Integration Cloud for streamlined access to asset-feature mapping.
• Outbound synchronization (to ESRI ArcGIS) for any attribute changes to existing assets in Oracle Utilities Work and Asset Cloud Service.
The integration will be facilitated via Oracle Integration Cloud and will include flows for synchronizations between both ESRI ArcGIS and Oracle Utilities Work and Asset Cloud Service.
The following diagram illustrates the business processes supported in this integration:
