Managing Web Service Catalog
The web service catalog is used by Oracle Integration Cloud to communicate with the respective application. It is used to identify the services that should be retrieved by the Oracle Utilities Adapter. It is configured in the Catalog URL in the Oracle Integration Cloud connection.
To configure the catalog in Oracle Utilities Digital Asset Cloud Service:
1. Login to Oracle Utilities Digital Asset Cloud Service.
2. Navigate to Admin > [W or Integration] > Web Service Catalog. Alternatively, you can search for the Web Service Catalog page from the Search menu.
3. Select REST Web Service Class.
4. Add the following REST inbound web services to the catalog.
Service Type
Service Name
Description
Inbound Web Service
F1-HealthCheckREST
Health Check
Inbound Web Service
F1-SyncRequest
Master Data Synchronization
Inbound Web Service
X1-ControllableDeviceStatus
Controllable Device Status
Inbound Web Service
X1-ProgramEnrollment
Program Enrollments
Inbound Web Service
X1-ProgramEvent
Program Event
Inbound Web Service
X1-ProgramEventParticipation
Program Event Participation
5. If applicable, for outbound messages, add the External System that was set up previously.
For more information about configuration, refer to the Oracle Utilities Work and Asset Cloud Service documentation available at Oracle Help Center.
