Supported Applications
The following table shows the supported application versions in this integration:
Application
Version
Oracle Utilities Digital Asset Cloud Service
25.10 or higher
Oracle Utilities Edge Distributed Energy Resources Management System
V2.6.0.2.6 or higher
Oracle Integration Cloud
V25.10 or higher
Refer to the
Certification Matrix for Oracle Utilities Products (Doc ID 1454143.1)
on
My Oracle Support
to determine if support for newer versions of the listed products is included.
This site works best with JavaScript enabled
