Migrating from OIC Test Environment to Production
Make sure all Oracle Integration Cloud artifacts are imported successfully.
To import the customizations added in the test environment to production:
1. Export the wacs_ofsc_fieldwork_custom_25.10 package from the test environment and import it into the production environment.
2. Configure all your connections in the Connections section of the Accelerator project.
3. Activate the base integrations and customized integrations, and configure the respective end point URL into the Oracle Utilities Work and Asset Cloud Service Message Sender.
4. Deactivate the base integrations for which a cloned, customized integration copies were created.
5. Deactivate the base integrations that are pointing to the older versions.
