Supported Applications
The following table lists the supported application versions in this integration:
Version
Oracle Utilities Work and Asset Management
V25.4 and higher (on-premises version)
Note that the integration will work, but the functionality will be limited.
Oracle Utilities Work and Asset Cloud Service
V25.10 and higher
Oracle Integration Cloud
25.02.2 and higher
Oracle Field Service
25A and higher
