Creating a Backup
Take a backup of the following:
• Oracle Integration Cloud Pre-built Integration Project: If the accelerator is project-based, export the Oracle Integration Cloud project. Click Export on the navigation bar for the respective project.
To export the project:
a. Login to Oracle Integration Cloud.
b. Navigate to Projects.
c. Select the project to be exported.
d. Click Export on the navigation bar list.
• Oracle Integration Cloud Pre-built Integration Package: If the accelerator is package based, export the Oracle Integration Cloud package and integration flows from Oracle Integration Cloud and store them in the local folder.
Note: If the base project is cloned and customizations are included in the cloned flows or if an older version of the project existed before consuming Oracle Integration Cloud accelerator project, take a backup of the Oracle Integration Cloud project.
To export the package and integration flows:
b. Navigate to Packages from integrations.
c. Select the required package to be exported.
d. Browse to the path where the package should be exported to and click Export.
• Oracle Field Service Properties: Export the Oracle Field Service properties that start with “wam_” and store/save them in the local folder.
• Oracle Field Service User Type: Export the user type file from the Oracle Field Service environment.
• Oracle Field Service Plugin: Export the Oracle Field Service plugin from the Oracle Field Service environment.
For detailed steps to create a backup, refer to the Oracle Utilities Work and Asset Cloud Service Integration to Oracle Field Service Configuration Guide included in this release. The documentation is available on the Integrations page on Oracle Help Center.
