Supported Application | Version |
Oracle Utilities Work and Asset Management | V2.4.0.1.2 or higher (on-premises version) Note that the on-premises versions (Oracle Utilities Work and Asset Management) may have limited functionality as they trail cloud-based versions (Oracle Utilities Work and Asset Cloud Service) due to the release frequency. |
Oracle Utilities Work and Asset Cloud Service | 25.4 or higher |
Oracle Integration Cloud | V24.02 or higher |
Oracle Field Service | 24B or higher |
ESRI ArcGIS Field Maps | 25.4 or higher |
