Field | Conditions |
DESCRIPTION | Mandatory for Work Order and Work Request |
DETAILED_DESC | |
ACTIVITY_TYPE | • Relevant for Work Order only • Mandatory for Work Order |
WORK_PRIORITY | Mandatory for Work Order and Work Request |
WORK_CLASS | |
WORK_CATEGORY | |
WORK_TYPE | • Relevant for Work Order only • Mandatory for Work Order |
REQUIRED_BY_DATE | Note: The date entered should be a future date. Else, will fail to create a work request in WAM. |
DOWNTIME_START_ DTTM | Relevant for Work Request only Note: The date entered should be a future date. Else, will fail to create a work request in WAM. |
WORK_IT | Relevant for Work Order |
EMERGENCY | Relevant for Work Order |
CREW_MEMBER | This field can be used to enter the field worker userID or the Crew userId if the work order needs to be assigned to the crew. If the CREW_MEMBER field is empty, the crew member user ID is taken from CREATOR field to create work order and work request in OFS. Note: • If the CREW_MEMBER field is used, the field worker who is creating the work order or work request must input userId of self or the userId of the crew. While there is no validation on the field itself, the field worker cannot input userId of another worker as it is not supported functionally. • In the standalone ArcGIS Enterprise server, if the Task feature layer is deployed as REST feature service, the CREATOR field will store the Enterprise Server manager user through which the REST Service is protected. |
GISID | This is the Global Id of the Asset on which Work Order or Work Request is created. This value is searched in WAM/WACS system to retrieve asset related information to create Work Order or Work request against. This value should not be updated manually and so this field can be made read only. This is required for Work Order. Work request can be created on a non asset. Work Order can be created only on a asset. Required can be enforced by making it visible and applying Work Order related required condition. |
TASK_TYPE | The value of this field is a Work Order or Work Request. The selection on this field can be used to show or hide Work Order and Work related fields. The selection can also be used to enforce required fields for Work Order or Work request. The value of this field is not used in Work Order or Work request creation as such. |
Field | Purpose |
EXTERNAL_REC_INFO | Default value is ‘N’. All records marked with ‘N’ are picked up for processing by OU ArcGIS OFS Work Tasks. After processing successfully, this field has the work request ID or mobile activity ID for work orders. |
CREATOR | Editor tracking field. If the CREW_MEMBER field is empty, value from this field is picked up to pass as resource to OFS during work request creation. |
CREATIONDATE | Editor tracking field. |
EDITOR | Editor tracking field. |
EDITDATE | Editor tracking field. |
