Multiple Portal Servers
OU ArcGIS WACS Initial Assets Sync and OU ArcGIS WACS Incremental Assets Sync are configured out of the box to support three ESRI ArcGIS portal servers.
Each of the Asset class in the OUTL-BRT-ArcGIS_WACS_AssetClass lookup can point to any of the three servers. Each of the servers are represented by serverIds S1, S2, and S3. Note that the integration flows consider only these three IDs.
The connection OU REST ArcGIS for ArcGIS-WACS is invoked when the ServerId field in the OUTL-BRT-ArcGIS_WACS_AssetClass lookup is “S1” or empty.
OU REST ArcGIS for ArcGIS-WACS S2 is invoked when the ServerId field is “S2”.
OU REST ArcGIS for ArcGIS-WACS S3 is invoked when the ServerId field is “S3”.
If the portal server support is needed other than three connections, clone the project.
