ESRI ArcGIS APIs
Query field in the OUTL-BRT-ArcGIS_WACS_AssetClass lookup represents the SQL filter statement for filtereing the features retrieved. Make sure the syntax specified in the Query field of the lookup as specified in the documentation for “where” parameter.
Extract Changes is another ESRI ArcGIS API invoked in the integration flows. This API requires to enable the ChangeTracking capability. For Enterprise geodatabase-based feature services published from ESRI ArcGIS Pro 2.2 or later, the ChangeTracking capability requires all layers and tables to be either archive enabled or branch versioned and have globalid columns.
