ESRI ArcGIS API Processing
The OU ArcGIS WACS Assets Sync flow iterates over each row in the OUTL-BRT-ArcGIS_WACS_AssetClass lookup and initiates an Incremental/Initial sync flow asynchronously. Each of the instance of the Incremental/Initial flow work independently to process the respective feature layer.
To accommodate multiple invocations to work parallelly, each feature service in the ESRI ArcGIS Enterprise server must be configured with adequate number of instances and suitable timeouts periods.
