ESRI ArcGIS to WAM/WACS Extendable Lookup Mapping
The product can be configured to support various mapping approaches between the ESRI ArcGIS features and assets. The following are high level guidelines to consider when designing such mapping:
Analyze your GIS asset classes. Determine which asset classes should be synchronized.
Determine which GIS fields should be synchronized.
Determine if the value mapping is needed for some GIS values.
Extend the base asset location business object if custom GIS location details need to be supported. Use asset attributes when possible, to store GIS asset related details. Define corresponding non-tracked Asset Types and Asset Location Types.
For each synchronized asset class define the following:
Custom value mapping extendable lookups for specific GIS field values that may need to be mapped to different values.
A GIS to Oracle Utilities Work and Asset Cloud Service/Oracle Utilities Work and Asset Management extendable lookup.
Note that the W1-GISIntegrationConfiguration Inbound Web Service (REST) will provide the asset class mappings details of GIS to Oracle Utilities Work and Asset Cloud Service/Oracle Utilities Work and Asset Management extendable lookup. It is used to configure the Asset Sync lookup in Oracle Integration Cloud.
