Configuring Lookups
The following table lists the lookups that are part of this integration.
Lookup Name
Integration Name
Purpose
OUTL-BRT-ArcGIS_WACS_ConfigProps
• OU WACS OIC GISMappings Sync
• OU ArcGIS WACS Assets Sync
• OU ArcGIS WACS Initial Assets Sync
• OU ArcGIS WACS Incremental Assets Sync
Generic properties used in the integrations business logic and mappings.
OUTL-BRT-ArcGIS_WACS_Email_ID
• OU Common Notification Handler
Provide email information to send the notification.
OUTL-BRT-ArcGIS_WACS_AssetClass
AssetClass information that have been refreshed from Oracle Utilities Work and Asset Cloud Service and adapted by the customer ESRI ArcGIS implementation.
Editing Lookups
To edit a lookup:
1. Login to Oracle Integration for Cloud.
2. Navigate to Projects.
3. Select the project and then navigate to the Lookups section of the project.
4. Select the lookup to edit.
5. Make the necessary changes.
6. Click Save and Close.
