Configuration Properties
The OUTL-BRT-ArcGIS_WACS_ConfigProps lookup contains the properties that can be defaulted in the integration. It also contains a flag to enable email notifications.
Property Name
Sample Value
Description
Used in Integration Process Name
wacs.file.target.transfer.pref
os
Defines the WACS file location preference.
Valid values: os|ftp
• OU ArcGIS WACS Initial Assets Sync
• OU ArcGIS WACS Incremental Assets Sync
wacs.os.namespace
wacsnamespace
WACS Object Storage namespace serves as a container for all WACS related buckets and objects.
Required to be populated when WACS is in the cloud, wacs.file.transfer.pref = 'os'.
wacs.os.bucket.assetsync
ArcGIS_AssetSync
Define the bucket name where the Asset Sync extract files should be dropped in the WACS Object Storage by OIC.
wacs.ftp.directory.assetsync
/scratch/AcrGIS_AssetSync
WACS FTP directory where the Asset extract files are dropped by OIC.
Required to be populated when WACS is on-premises, wacs.file.transfer.pref is = 'ftp'.
notification.type.email.flag
true
If the value is set to 'true', email notification will be sent out for errors.
Valid values: true|false
Default: true
• OU WACS OIC GISMappings Sync
• OU ArcGIS WACS Assets Sync
notification. email.process.complete.flag
true
If the value is set to 'true', email notification will be sent when Asset files have been created and dropped in the respective location.
Default: true
wacs.projectedcoordinates ystem.wkid
4326
This property is used to configure the coordinates system [wkid] which will be used to retrieve the geometry coordinates in the specified system format.
sync.initial.maxresult.count
2000
sync.increment.objectid.count
1000
The OUTL-BRT-ArcGIS_WACS_Email_ID lookup contains the properties that can be defaulted in the integration. It also contains a flag to enable email notifications.
Property Name
Sample Value
Description
from
ArcGIS_WACS@email.com
Defines the ‘from’ email address on the notifications.
• OU Common Notification Handler
to
errorDist@myCy.com
The email address(es) who should receive any error notification. Multiple emails can be configured by putting comma to separate the email IDs.
These are likely the administrators or users who maintain the applications.
to.process.notification
bizDist@myCy.com
The email address(es) of who should receive notification when the processing has completed. Multiple emails can be configured by including comma to separate the email IDs.
These are likely the business or application users.
The OUTL-BRT-ArcGIS_WACS_AssetClass lookup contains the assets that are configured in Oracle Utilities Work and Asset Cloud Service and are located in ESRI ArcGIS. It also contains customizable columns that relate to ESRI ArcGIS locations.
This lookup is primarily refreshed by the OU WACS OIC GISMappings Sync integration and adapted to the customer ESRI ArcGIS implementation.
Column Name
Sample Value
Description
Comments
AssetClass
Pump_Centrifugal
Name of the Asset stored in WACS.
Updated by the synchronization flow.
Attributes
LIFECYCLESTATUS,GLOBALID
Attributes associated with the asset
Query
RelativeURI
relative1/FeatureServer/501
URI from this asset feature. It has to end as: /FeatureServer/{ID}
ID after the FeatureServer is required to be retrieved in the ESRI ArcGIS portal.
ServerId
S1
ESRI ArcGIS portal instance
Used to direct to the appropriate configured connections documented in Chapter 4: Importing, Configuring, and Testing Integration Connections.
