Supported Applications
The following applications are required/supported in the integration:
• Oracle Utilities Work and Asset Management
Note that the on-premises versions (Oracle Utilities Work and Asset Management) may have limited functionality as they trail cloud-based versions (Oracle Utilities Work and Asset Cloud Service) due to the release frequency.
• Oracle Utilities Work and Asset Cloud Service
• Oracle Integration Cloud
• ESRI ArcGIS Enterprise V11.3
For specific application versions, refer to the ESRI ArcGIS Integration to Oracle Utilities Work and Asset Cloud Service Release Notes included in this release. The documentation is available on the Integrations page on Oracle Help Center.
