Solution Diagram
The technical aspects involved in ESRI ArcGIS integration to Oracle Utilities Work and Asset Cloud Service are:
• An integration between ESRI ArcGIS and Oracle Utilities Work and Asset Cloud Service.
• The integration layer is made up of integration processes deployed on Oracle Integration Cloud.
• It uses batch services and REST APIs to facilitate communication between the two applications.Shows the solution diagram for the integration.
